1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics driver & device support for IRM
To: [email protected]
Cc: [email protected]
Date: Thu, 22 Aug 1996 12:15:08 +0200 (MET DST)
> We've looked at our future requirements, and while the IRM may not be a very
> good fit as it stands, the option of using a '162 with some of the large
> variety of IP cards available looks very interesting.
> Perhaps some discussion of creating a "standard model" for supporting IP cards
> under EPICS might be in order.  As the IP interface (including module
> identification) seems to fairly well specified, perhaps we could take advantage
> of that information in the system configuration and initialization process.
> Any ideas?  Is this worth spending some time on during the next epics meeting?
My opinion is the following:
 Must be separate the 'epics' and 'vwWorks' configuration. (Of course
 this two must be fit together)
 The Epics run-time configuration on version 3.13 is much more better
 then the 3.12. features. This is needed, and the Epics is on this way.
 (We in DESY useing some envinroment variable foe enable/disable device/driver
 support moduls on version 3.12.2.D (DESY add owns). This env. variable
 settings are in STARTUP script yet.)
 The VxWorks configuration part can be done on that case when the IP module
 drivers are independen from EPICS. At DESY we can do this useing our
 CDI interface and adding this configuration possibility to CDI. (Which is
 not in CDI V4.0, and a part is implemented in CDI V4.2 and plan to add more)
 In case of IRM the connection between Epics and IP module has been
 made by Epics driver support routine. So in thet case the proble
 is same as any IO card (pre)configured by Epics and not depend on IP module.
 At firs must be solve it in Epics. (hopefully it has been done in
 next release (?) or at least we get more flexible configuration possibility)
 I like the 'module' system, thats meaning yet: I use the same VxWorks
 image (per board type) and download different moduls or same moduls with
 different parameters, adding more feature for VxWorks kernel. After this
 download the same EPICS and configure from startup useing different
 values for the envinroment variablas.
As long as is possible I prefer this way to manage our IOC-s.
Gabor Csuka
DESY, Germany
Prev: Re: rec/devSup advise needed Gabor Csuka
Next: Re: epics driver & device support for IRM Matthias Clausen DESY -MKV2/KRYK-
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics driver & device support for IRM Bill Brown
