1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: rec/devSup advise needed
To: [email protected]
Date: Thu, 22 Aug 1996 17:22:14 -0500
>Andrew Johnson wrote:
>> IMHO the new formats should not be hard-coded anywhere other than the
>> drivers/device support which use them; the "link_type" in the database
>> "device" definition should be something else which is definable in an
>> ascii file (and convertable into a VME_IO.h file for example, which can be
>> #included by the device/driver).  This way anyone could add a new address
>> type without needing to rebuild base, but you should still be able to
>> retain backwards compatibility for existing device/driver support.
>I just read this more carefully. I think I now see what you are saying.
>Just like 3.13 has ascii definitions for menus and record types
>let it have an ascii definition for a link type.
Add support for these things to GDCT and you will be caught back up to the
hardware-config subsystem of RX ;-)
--John Winans
Prev: Re: mv162LC problem with floating point libraries in 5.1.1 Johnny Tang
Next: Re: rec/devSup advise needed Ric Claus
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: rec/devSup advise needed Tim Mooney
Next: tclCa package (was et_wish) Claude Saunders
