1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Migration Migraines
To: [email protected]
Date: Fri, 30 Aug 1996 07:42:41 -0500
Mark M. Ito wrote:
> Dear EPICS-guru-types,
> I am having trouble building databases on a Sun Ultra running solaris
> 2.5. db2database bombs when I introduce one of our non-standard
> records. This procedure has worked for us on a HP. On the Sun I get a
> segmentation fault in strcmp in extensions/src/mdct/klib/field.h while
> calling value_not_default(). The strcmp is between value() and
> this->get_default_value() and the latter comes back null. What is
> kinda interesting is that if I take my default.dctsdr from the HP and
> ftp it over to the Sun, db2database is as happy as a clam. I am told
> that I should suspect data structure alignment differences between HP
> and Sun. Full-word boundaries? Double-word boundaries? Arch Deluxe?
> Whopper w/ cheese?
> Anyone care to comment?
> Mark M. Ito, Thomas Jefferson National Accelerator Facility
> 12000 Jefferson Ave., Mail Stop 12H, Newport News, VA 23606
> Email: [email protected], Office: (757)249-7175, Pager: (757)680-7175
Since base release 3.13 uses all ascii database description and
instance files, alignment problems should not occur (assuming that
all code is compiled by compatible compilers).
Since db2database and default.dctsdr both go away for 3.13
it is worth pursuing this problem. Note that by relinking gdct
to use the 3.13 libDb it works with 3.13 databases. Details are in
the WWW release notes.
Marty Kraimer
Re: Migration Migraines Marty Kraimer
Migration Migraines Mark M . Ito
Prev: Migration Migraines Mark M . Ito
Next: Re: Migration Migraines Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
