1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: iocLog - wishlist
To: [email protected]
Date: Wed, 4 Sep 1996 08:15:35 -1000
Dear all,
Jeff Hill wrote:
> It would be easy to provide an option where the server creates
> a new file with the current date appended to the file name
> when it gets to the end of the current file?
I see the maximum size limit as being useful to avoid problems in error
situations where IOCs might start logging messages at a huge rate. At
least it avoids filling the disk. Note that if the limit is set to zero
then no truncation occurs (i.e. zero equals infinity).
Note also that the IOC log server now supports receipt of a SIGHUP
signal which causes it to execute the command supplied as the value of
the EPICS_IOC_LOG_FILE_COMMAND environment variable in order to
determine the directory part of the file name and then, if this is
different from what was already in use, to close the old one and open
the new one. We have a cron job which sends the signal at 5.30pm each
afternoon and places the new log file in a directory called
/xxxx/yy/mm/dd.
William
Prev: Re: iocLog - wishlist Jeff Hill
Next: PC GPIB performance watson
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
