1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A multiway switch record for the new switchable links.
To: [email protected], [email protected]
Date: Wed, 9 Oct 1996 14:19:52 -0500
> From [email protected] (Nick Rees)
> I have been using R3.13.0 alpha 5 for a while now, and even had
> occasion to use the switchable links. What we appear to need now is a
> switch record, and probably a multipole, multiway switch record.
> Anyway, has anyone thought about something along these lines? Has anyone
> got anything to add?
A switch record would be a convenient mechanism for connecting
predetermined sets of inputs and outputs (but that was already possible
in 3.12).  I think we also need simple improvements in existing records
to take better advantage of 3.13 links.  If the existing Select and
Sequence records could handle strings, they'd be a lot more useful in
databases to support link manipulation, and they'd give you the raw
materials from which you could build a multiway, multipole switch.
Even better, I think, would be a string-manipulation record: suppose I
need to connect some calculations to any of, say, 50 motors.  I'd want
to poke to the drive field "motorX.VAL", read from the readback field
"motorX.RBV", and monitor the done-moving field "motorX.DMOV".  I'd
like to let the user type in, say, "motor38", and have a database that
would make all three connections.  To do this, I'd need to write a
string-manipulation record, but I'd like to use standard EPICS records
to distribute the resulting PV names.
Tim
Prev: Should ai, ao records have RAWH, RAWL? LUCHINI
Next: EPICS software distribution Bakul Banerjee
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: A multiway switch record for the new switchable links. Nick Rees
Next: EPICS 3.13 Ric Claus
