1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: proposal: IOC logger
To: [email protected]
Date: Mon, 14 Oct 1996 21:52:45 +0100 (MET)
Salut, EPICS folks!
We have some proposal about IOC logger..
Problem background
  - Seperated log files to record the messages from different IOC's.
    But, some sites will continue to prefer to keep messages from several
    IOC's in one file.
  - Run time reconfiguration of iocLogServer.
  Proposal:
  - Use one configuration file to specify all parameters for the server.
  - One chapter should consist of information where messages from particular
    must be saved:
    <IOC name>|          <full path>  |<size limit>|<versioning>|<mail address>
    heraVME00 |/.../heraVME00_log.text|1000000     | Y          |[email protected]
    heraVME01 |/.../heraVME00_log.text|1000000     | Y          |[email protected]
    heraVME02 |/.../heraVME02_log.text|4000000     | Y          |[email protected]
    heraVME03 |/.../heraVME03_log.text|239093      | N          |
   * msg from heraVME00 and heraVME01 will be saved in ONE file
  - To add a new variable "EPICS_IOC_LOG_CONFIG_FILE" which should keep
    full path to the configuration file.
  - Send the signal SIGHUP (kill -1 <pid>) to iocLogServer to forse it to
    read config file again a make inner reconfigurations. (to be discussed)
    In start time:
    1. iocLogServer <path to config file>
    2. If ``config_file'' does not specify in command line then read
	system env. variable EPICS_IOC_LOG_CONFIG_FILE.
    3. If env. does not exist, then use today approach.
Problem background
   - Once the file is written fully, we need a possibility to inform
     the system manager about it and stop writing.
  Proposal:
   - IOC log sever will check itself whether a new month has started and
     crate new log file /xx/yy/mm/logfile.
   - Send a mail to the system manager to tell about this.
SU,
Xiaosong Geng
Re: proposal: IOC logger Jeff Hill
Prev: [Summary] Rs232c in EPICS Peregrine McGehee
Next: Re: proposal: IOC logger Jeff Hill
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
