1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Standard IOC Benchmarks?
To: [email protected]
Date: Wed, 16 Oct 1996 08:32:19 -0500
Peregrine McGehee wrote:
> Aloha,
>         Does anyone have a 'standard' set of IOC performance
> benchmarks? I mean besides the obvious running of dbt against a number
> of 'soft' records.
>         I'd like to generate some meaningful numbers for my Sparc 5s.
> Thanks,
>         Peregrine
anonymous ftp to epics.aps.anl.gov. Then
cd pub/dbperform
retrieve the files
perform.db
timeMeter.adl
The adl display brings up 100 meters each connected to a different
record. In addion the left side of screen has 10 menu controls
that allow you to set scan rate for records in that row.
At bottom are three menu controllers. Two allow you to set scan
rate for groups of 5 rows. The last sets scan rate for ALL meters.
This last on is connected to a fanout record that cause everything
to scan 3 times each time record is executed. Thus setting thi
to .1 second cause 3000 records/sec to process with monitors
going to display.
Run this and then start spy. Give results.
Marty Kraimer
Standard IOC Benchmarks? Peregrine McGehee
Prev: Re: proposal: IOC logger Gabor Csuka
Next: Re: FLAME medm John R. Winans
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Standard IOC Benchmarks? Jeff Hill
Next: Re: Standard IOC Benchmarks? Noboru Yamamoto
