1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: frc64/frc604RT performance
To: [email protected]
Date: Thu, 24 Oct 1996 08:12:14 -0500
Noboru Yamamoto wrote:
> Dear Colleagues,
> Here is a result of EPICS benchmark (perform.db and timeMeter.adl by Marty
> Kraimer) on Force CPUs.
> frc40 (MC68040 25MHz)
> scan    scanPeriod      IDLE    TOTAL
> 0.1     11.0%           70.4%   97.0%
> frc64(MC68060 50MHz)
> 0.1     9.46%           77.9%   96.0%
> frc604RT(PPC604 100MHz)
> 0.1     2.59%           94.9%   98.9%
> Ratio of CPU performances estimated from these numbers is,
>  frc40:frc64:frc604RT=1:1.3:4.1
I am not sure what should be reported but another way is % cpu
usage which is (100 - IDLE). This would give.
68040 26.8%
68060 22.1%
frc604 5.1%
Using 68040 as base and reporting as (68040 cpu)/(xxx cpu) gives
frc40:frc64:frc604RT=1:1.2:5.25
Not sure which way makes most sense but they give similar results.
I am really suprised by the 68060 numbers. Could you please
tell us the following:
For each cpu give
   a) Speed of main memory.
   b) Speed and size of cache memory.
Also are you sure all board support packages turned cache on?
Also is it possible to make up a small test case that just
has a loop to does an integer multiply and another loop that
does a double multiply? Make sure compiler doesnt optimize everything
away. This test should show raw cpu performance.
The database test may just be dependent on main memory speed
and size of cache.
Marty Kraimer
Re: frc64/frc604RT performance Johnny Tang
Re: frc64/frc604RT performance KAJI Masahiro
frc64/frc604RT performance Noboru Yamamoto
Prev: frc64/frc604RT performance Noboru Yamamoto
Next: Re: frc64/frc604RT performance Johnny Tang
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
