1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with sync groups and C++ clients
To: Guy Jennings <[email protected]>
Cc: [email protected]
Date: Wed, 06 Nov 1996 11:17:31 -0700
Guy Jennings wrote:
> Epics folk:
> I recently ran into a problem while attempting to use a sync group from
> a C++ client application.  The code below is based on acctst.c in the
> epics
> distribution.
>         /* int ca_sg_create(const unsigned int *g); */
>         int     status;
>         CA_SYNC_GID     gid=0;  /* const unsigned int gid = 0; */
>         printf("Initially %ud\n", gid);
>         status = ca_sg_create(&gid);
>         SEVCHK(status, NULL);
>         printf("Then %ud\n", gid);
> If compiled with gcc the code works fine, with the ca_sg_create call
> initialising
> 'gid' to a non-zero value (45 in my case).  If compiled with g++ the
> code does not
> work correctly and 'gid' retains the value 0 after the call to
> ca_sg_create.  This
> appears to be due to the definition of CA_SYNC_GID as 'const unsigned
> int'. I think
> it would be safer to remove the const from the typedef for CA_SYNC_GID
> since at
> present you are relying on undefined behavior - (typecasting away the
> const in
> ca_sg_create).
> As far as I can tell, CA_SYNC_GID is the only epics-defined type which
> displays this
> problem and the header already allows for CA_SYNC_GID not to be 'const'
> Guy Jennings
> BESSRC CAT
> Argonne National Laboratory
I also discovered this problem during testing about a week ago. This
appears to track with GNU C version 2.7.2 (I saw the bug when I compiled
with gcc 2.7.2 and I used the -O flag). I also arrived at the conclusion
that the use of "const" in the typedef for CA_SYNC_GID only leads to
problems - so I removed it. This should not require any change in
any of the CA clients. I recently committed this change to 3.13 beta
at APS.
If there is interest I will patch 3.12.
I have only seen this problem show up when compiling with gnu C/C++ 2.7.2
(which is not distributed with vxWorks 5.2).
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Problem with sync groups and C++ clients Guy Jennings
Prev: Problem with sync groups and C++ clients Guy Jennings
Next: Re: seqChanShow switches Rozelle Wright
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: How to connect to mbbo records? Len Lawrence
