1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Hardware Configuration
To: [email protected]
Date: Fri, 22 Nov 1996 13:07:26 +0000 (GMT)
Chip is right in rejecting the idea of having a single h/w config record
per signal, and possible ever per I/O card/module is too much. Marty's
record defines setups for a whole field-bus, which is a reasonable level
of overhead.  For CANbus I give this sort of data to an initialisation
routine in the startup script, but there are reasons why some sites don't
want to do this.
I like the idea of being able to define a record type which doesn't
support the whole of dbCommon. In fact I wonder whether we could make some
fields optional by putting them in a sub-structure (say one for CA monitor
fields, another for scan fields etc).  Why should *every* record type have
to support ASGs, Scan types, Disabling, Channel Access monitors, Alarms
and Forward Links?  Most will, but I can forsee simplified record types
for which some of these aren't necessary.
For example, a common use for an AO record is to get a value from
somewhere and put it elsewhere. This doesn't need alarms or monitors
necessarily, so there could be a simple "copy" record which just does this
job.  It ought to be possible to maintain backwards compatibility while
adding features to support these simplified record types, and Hardware
Configuration records have similar kinds of characteristics.
- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: Hardware Configuration watson
Prev: VxWorks ramblings Steve Lewis
Next: bug in the sequencer Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Hardware Configuration watson
Next: Re: Hardware Configuration Marty Kraimer
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
