1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: next release
To: [email protected]
Date: Fri, 6 Dec 96 09:54:11 MST
X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Content-Lines: 17
As 3.13 is coming to a close - it is time to look into the future and
determine the direction of our efforts. I have included a list of work
that the technical staff at Los Alamos considers important to the
future.
This letter has two goals:
1) To hear what you think has relative importance to your group/projects
Your technical opinions are part of your contribution to this collaboration.
2) To hear what you are willing to spend time and/or money to get done
Your opinion is welcome (see 1). Your participation is valued. This will
help us to organize our combined resources to get the most impact out of
our shared resource.
Bob
X-Sun-Data-Type: default
X-Sun-Data-Description: default
X-Sun-Data-Name: Next_release
X-Sun-Content-Lines: 65
Archiver:
Buffer Server -> CAC ->	Frequency -> S/C -> 	Java Viewer
Vectors		 CDEV	Monitor			XARR
Arrays			Save Set		SDDS
			Scope			PC?
Config Tool for data taking engines
Pentium Drivers in the Pentium IOC:
Industry Pack
Fire Wire
Allen-Bradley
Modbus
Online Add/Delete
Drivers
Device Support
Record Types
Record Instances
PC Visualization
MEDM/DM Merge - then port
Rewrite
Use something commercial
Archive data viewing and analysis
Portable CAS connected to the database
Must precede any CA protocol changes
CAV4
Large Array Support
Protocol Compression
Client to call server directly
-Name server / name cache
Redundancy
Does anyone need this -
To what extent do we make things redundant
Support multiple O/S - NT/VMS/Unix etc....
Put Makefile.Host into release
Do we need to improve install procedures
Portable expression evaluator
Ability to create expression with a server that run on
any OS
Any other pressing topics?????
Prev: Re: CaWave Steve Lewis
Next: Burt under Solaris Rolf Keitel
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
