1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Capfast question: linking to ao .VAL field?
To: [email protected]
Date: Mon, 9 Dec 1996 09:21:48 -1000
Dear all,
  I have an application where I want to connect a PP output link (of a
genSub record) to the VAL field of a passive ao record (so I can use the
ao as the external interface rather than having CA clients link directly
to a genSub field; I wanted to avoid a periodically scanned ai).
  This doesn't work. I thought this might be because no records
reference the VAL field in edb.def so I added such a reference with a
default of 0.0, but this caused e2sr to complain:
Warning: Property or port "VAL" does not exist, using default value.
  Should I able to do this? If so, how should I do it?
  William
Prev: Re: Burt under Solaris Jeff Hill
Next: subscribe Steve Hunt
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Capfast question: linking to ao .VAL field? William Lupton
