1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: IP support
Date: Fri, 13 Dec 1996 18:19:19 +0100 (MET)
Jim writes:
>I've been reading the IP support mail messages over the last couple of
>hours on tech-talk and I guess I have a question about all of it and a
>few comments.  I've read through all of your stuff, so I might as well
>throw my stuff out here too.
>I see three basic IP developments in process, maybe four:
> 1) telescope community (Andrew/Peregrine)
> 2) IRM developments and other (Matthias/DESY/Fermilab)
> 3) HiDEOS
In fact there are several ways to communicate with serial IP's:
-telescope community (Andrew/Peregrine) partly using HIDEOS
-DESY using CDI (which runs under VxWorks and support single and multiple CPU's)
-ANL HIDEOS
-BESSY - there way to do it
There have been enough arguments about HIDEOS/CDI and others.
It's not religious. There are finacial arguments: (HIDEOS does not need VxWorks licences)
Technical arguments etc. and I do not believe that any programmer who did this job will
want merge his code with another one.
The actual version of CDI is now optimized for asynch. I/O and can handle even bulk data
with might be connected to sevel(hundred) of EPICS records in a most efficient way. This
development took Gabor a lot of time to optimize the code. I am sure we will not want to
move to any other code.
You as the EPICS community have tha chance to pick what you like.
Looking at the history of CDI - this in fact was already running 1 year before HIDEOS was
developed because we already used it under VAX-eln (who ever knows this 'strange'
operating system). But this only for clarification.
The arguments for the register-based drivers for IP modules are surely true and  in fact
the drivers written for the IP-modules in the Fermilab-IRM's are NOT using CDI but are
written in the same way as any other VME-IO drivers.
Are there so many common aspects on the IP drivers that you might want to standardize on?
What's the difference to the VME drivers?
Well - it would be worth thinking of something like auto-configuration of IP modules...
Is this the idea?
We need in general some standards:
for serial IO we already have at least 4
for direct IO ?
- auto configuration?
- others?
Matthias
Re: IP support Ralph Lange
Prev: Re: IP support watson
Next: IP conversation, my 2 cents RON
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: IP support Ralph Lange
