1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IP support
Date: Fri, 13 Dec 1996 17:47:54 -0500 (EST)
Jim,
On Fri, 13 Dec 1996 07:58:20 -0600 "Jim B. Kowalkowski" <[email protected]>
wrote:
> I see three basic IP developments in process, maybe four:
>  1) telescope community (Andrew/Peregrine)
>  2) IRM developments and other (Matthias/DESY/Fermilab)
>  3) HiDEOS
4) Kay-Uwe Kasemir's driver, which is PC-aware.
> My main question is this: What is the main reason that you (supporters and
> users of 1 and 2) have dismissed HiDEOS?  Much (not all) of the development
> in 1 and 2 has been done after the HiDEOS development.  I'm really not trying
> to sell HiDEOS or anything, I just want feedback.
I'll try and list as many reasons as I can think of.
1. The HiDEOS IP software will only work on an mv162 CPU, or (with some
changes) on a carrier board based around the IPIC chip.  I had a long look
at the source-code for the HiDEOS driver before concluding that we
couldn't use it.  The GreenSpring VIPC-310 and -610 IP carriers which I
had to support are *totally* dumb; you can only change the interrupt
levels by blowing a new PAL, and the base addresses are set by jumpers.
Neither setting can be discovered by reading a register, because there are
no registers.  Autoconfiguration of the carrier boards is thus impossible
-- if you don't have an IP module installed you can't tell whether there's
a carrier board there or not.  I forget if your software provide a means
of manual configuration or not, but you certainly need it to support the
GreenSpring carriers.  The carrier driver software would also have to
provide a way of telling a module driver "sorry, you can't do that with
this carrier" and I couldn't see how with your current interface.
2. We needed to be able to install multiple carrier boards simultaneously,
and we might have needed to be able to add a GreenSpring card to a system
that was already using the mv162, hence loading two different carrier
drivers.
3. Yes, C++.  I agree it's the way things are moving, but we would have
had to jump through some hoops to get Gemini (the customer) to agree to
our using it.  I also failed to build the g++ cross-compiler, which didn't
do much for my confidence in the approach.
4. We found it difficult to justify loading what seemed a non-trivial
amount of HiDEOS software on top of EPICS just to be able to communicate
to one type of IP module (a similar reason for our rejection of CDI BTW).
> I think it would be nice if we could have a unified IP support package
I think it is crazy *not* to have a unified IP support package, but IMO
there wasn't anything suitable before I wrote drvIpac.  I'm willing to
modify my CANbus driver to run under anything that we decide upon as a
standard, provided it supports the GreenSpring boards sensibly.  I suspect
that drvIpac is the most general-purpose of all the IP support packages,
but I'm not saying we *have* to use it.
- Andrew
   ___
 .'   `.        Andrew Johnson, Head of Electronics
/ Royal )       Royal Greenwich Observatory
\ Greenwich     Madingley Road, Cambridge, CB3 0EZ
| Observatory   Tel: +44 1223 374823   Fax: 374700
+----------     WWW: http://www.ast.cam.ac.uk/~anj
Prev: Re: "EPICS for Idiots" Steve Lewis
Next: Re: VME: Cannot find record type dfan Marian Zurek
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IP support Peregrine McGehee
Next: IP conversation, my 2 cents RON
