1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS database & channel access
To: [email protected]
Date: Tue, 17 Dec 96 17:06:11 -0500
Jeff said:
>If the client's sustained event consumption
>rate is slower than the scan task's sustained event consumption
>rate then we will eventually overflow the finite buffering system.
>Likewise if the average available network bandwidth constrains the
>event transmission rate to the client to the point where it
>is slower than the event production rate then we will also
There is one other important senario for lost data that I am trying
to address: CPU cycle starvation of the CA client tasks.  In this
senario, the network client is happily waiting for data and flow
control does not come into play.
>1) The scan tasks consume enough CPU so that the server is
>starved for CPU.
>       SOLUTION=> split into two IOCs or buy new CPU
The starvation is random and not sustained, and it is wasteful to
double the CPU power of the entire system to deal with this problem.
Approximate cost for this solution: $200,000.
>Another problem: If we make socket calls from the scan tasks
>then their maximum stack consumption may increase. Do a tt()
>on one of the event tasks while it is running a few times
>if you would like to see how many subroutines deep the
>IP kernel goes.
This is not a serious problem.  We use this technique in our high
bandwidth data acquisition systems (>1MB/sec over ethernet), and our
stack sizes are not that large.  Also, since I am proposing greatly
reducing the number of stacks, even doubling it is not an issue.
>Intermediate monitors will be dropped in a consumer producer system where
>the sustained production rate is higher than the sustained consumption
>rate if we are not willing to suspend event production (fact of life).
Agree.  If the client is too slow, we must keep the current behavior of
discarding data.
>Con: No preemptive multi-tasking. ie the alarm client is not allowed to be
>serviced at a higher priority than some of the scan tasks etc. We dont do
>this now but perhaps we would like to.
We could deal with this by having multiple servers, i.e. a known port for
high priority, another for medium, another for low.
Chip
Prev: Re: devLib Bill Brown
Next: Re: EPICS database & channel access Jeff Hill
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS database & channel access Jeff Hill
