1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Should dfanout be called dLoFanout?
To: [email protected], [email protected]
Cc: [email protected]
Date: Thu, 19 Dec 1996 08:48:31 -0600
> > Marian Zurek
> > CERN
> Hi Marian,
> I finally looked closely at the dfanout which is in the EPICS
> distribution.  All of the values (including of course HOPR and LOPR)
> are defined as long integers.  This explains why you get an error
> when you try to set HOPR to .5 from the opi.
> Does any one else have a copy of a floating point data fanout already?
> Good Luck,
> Rozelle
The "sequence" record can work as a data fanout for floating point numbers.
There are 10 "put" links, and each one can get data from a different PV. If
all of the inputs are defined the same, you have a data fanout. You also
get the added bonus of specifying a delay between link execution.
	Ned
Prev: Re: User's Guide on EPICS Build System Marty Kraimer
Next: Re: Should dfanout be called dLoFanout? Johnny Tang
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Should dfanout be called dLoFanout? Rozelle Wright
Next: Re: Should dfanout be called dLoFanout? William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
