1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Should dfanout be called dLoFanout?
To: [email protected]
Date: Thu, 19 Dec 1996 16:04:02 -0500 (EST)
Rozelle wrote:
> I finally looked closely at the dfanout which is in the EPICS
> distribution.  All of the values (including of course HOPR and LOPR)
> are defined as long integers.  This explains why you get an error
> when you try to set HOPR to .5 from the opi.
> Does any one else have a copy of a floating point data fanout already?
Why do the dfanout, sequence and select records have to have a data type
in the first place?  Their fuction is data handling, not processing, so
they don't need to understand the data at all.
[I'm excluding the high/low/median function of the select record for the
purposes of this discussion -- we still need a numeric Maximum, Median,
Minimum record type which should conceptually also include the index
selection mechanism as well]
It ought to be possible to create type-less versions of these which could
also work with strings and arrays, the data type of the record value being
determined by whatever is input (or by an FTYP field).  You lose out on
the ability to specify deadbands and alarm limits on the select/dfanout
value, although these could be implemented by adding a suitable output
record before the dfanout or after the select.
- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: Should dfanout be called dLoFanout? Johnny Tang
Prev: Re: RE: User's Guide on EPICS Build System Andrew Johnson
Next: Re: Should dfanout be called dLoFanout? William Lupton
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Should dfanout be called dLoFanout? William Lupton
Next: Re: Should dfanout be called dLoFanout? Johnny Tang
