1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PC/WIN32 Display Options
To: [email protected]
Date: Wed, 08 Jan 1997 15:56:33 -0700
Dear Reader:
This is a status report on EPICS Display Tools for WIN32.
For the impatient the 'bottom line' first:
        National Instruments' Lookout seems to be a good option
        for a PC based EPICS display manager.
Now some more details, also available nicely? formated! as
http://atlanta.atdiv.lanl.gov/WIN32EPICS/Display.htm,
at least when the Web server on my PC is running.
While there is still no full-blown EPICS specific display tool available
for Windows95 or NT (like edd/dm or medm for Unix),
we do already have some options:
1) Ca and EZCA DLLs
   These are part of EPICS base and extensions resp. and in fact
   this option has been available for some time now after Chris Timossi
   has ported the Ca client code to WIN32:
   Other that on Unix where you can use libraries almost only by linking the
   code to your C(++) programs,
   Windows DLLs (dynamic link libraries) can be used by
   almost any Windows program which provides a macro language.
   A good example might be MS Excel, where after putting a few lines of VBA code
   in your spreadsheet you can use formulars like this
	=GetCAValue ('HighlyImportantPV')
   and the cell will reflect the current value of the given PV every time you
   update the spreadsheet.
2) Ca DDE Server
   The DDE server for channel access allows DDE-capable Windows applications to
   monitor and modify process variables.
   This was originally written for Lookout (see below) but can also be used by
   e.g. Excel.
   The advantages are:
   a) It's easier to use, just put a line like this in your preadsheet:
           ==CaDDE|Get!'HighlyImportantPV'
      - no additional VBA code needed!
   b) You automatically get dynamic updates every time the PV changes!
3) 'EDM', the WIN32 Epics Display Manager
   A WIN32 Display Manager is in developement.
   It should offer similar features like edd/dm.
   The basic class layout seems to be done,
   some simple display elements as well as OLE support are implemented.
   After implementing more editing features (alignment, multiple selections) and
   an ASCII import/export it should be usable by the end of January 97.
4) Lookout, the main reason for this mail:
   CaDDE allows you to use National Instruments' Lookout as
   an EPICS display manager.
   It has some limitations, partly in performance and partly because it was
   not originally developed for EPICS.
   All in all, however, this might right now be the most
   complete option available:
   * It offers many predifined types of switches, sliders, bar graphs
     and you can also use your own bitmaps.
   * Many editing features.
   * Performance might be OK for most applications.
   * Easy to use interface to EPICS via CaDDE, basically you select
     'from DDE' and type 'CaDDE', 'Get', <your PV name>.
   * Some archive and history tools included.
   For more information please refer to
        http://atlanta.atdiv.lanl.gov/Lookout/main.htm
-Kay
Re: PC/WIN32 Display Options watson
Prev: Re: flaky IOC problems at Jefferson Lab watson
Next: [no subject] Bob Dalesio
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: flakey IOC problems at Jefferson Lab Eric Bjorklund, NPSM
Next: Re: PC/WIN32 Display Options watson
