1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fieldbus's
To: [email protected]
Date: Thu, 9 Jan 1997 14:33:53 -0500 (EST)
>> Hello All,
>>       We have been looking at fieldbus's to replace the BITBUS for
>> new projects at Bates.  Both PROFIBUS and CAN look promising.
>> Can someone comment on the advantages or disadvantages of PROFIBUS
>> verses CAN?
>> Thanks,
>> Coles Sibley
>Hi Coles,
>  We're in the same situation. Please keep us informed on what you
>  find out. Currently, we are investigating the Universal Serial Bus
>  that is coming out for the PC's to see if it is applicable as a
>  field bus. It will be cheap, well debugged, well supported, and
>  well documented (unlike Bitbus). Not sure if it will work over
>  fiber ...
>  	Keep in touch -
>  		Ned
Hi Ned,
Have you looked into the Foundation Fieldbus?  The Foundation Fieldbus
is the result of a merger between the Interoperability Systems Project
ISP and WorldFIP.  It's a very new standard in the US and is in the
process of being standardized worldwide(?) as the ISA/IEC SP50 specification.
speed (H2) @500m	2.5 Mbit
data per packet		1000 bytes
(lots more data at www.fieldbus.org/business/information/ffmain.html)
commercial support
	Several companies have commercial developers packages
	available but commercial availability of remote IO is
	not expected until later this year.
Coles
Prev: Re: flaky IOC problems at Jefferson Lab watson
Next: Re: PROFIBUS vs CAN John Maclean
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PROFIBUS vs. CAN SIBLEY
Next: edd 2.2, Solaris 2.5 and Sun patch 103210-09 Andrew Johnson
