1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Make, Scripts, Shell, Perl!?
To: [email protected]
Date: Wed, 29 Jan 1997 09:18:52 -0800
>As I understand it perl is also free. It is certainly a negative
>to require its installation into UNIX prior to building EPICS.
>Nevertheless, we are considering it because we end up installing
>far less on other OS such as windows{NT,95} if perl is used
>to replace shell scripts (and use of awk, sed, grep, pwd, ...}.
It's also a negative to install gmake on UNIX (and a real negative, in
my opinion, to install gmake on NT), but people seem to have
felt it was worth biting the bullet to gain the features.
The alternative to Perl is to write some C programs. If the scripts
are simple and there arent plans to add a bunch more, this may be the
most portable solution (though you still have to deal with the '/' vs
'\' difference somewhere).
Chris
Prev: Re: Make, Scripts, Shell, Perl!? Jeff Hill
Next: Re: Make, Scripts, Shell, Perl!? Kay-Uwe Kasemir
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Make, Scripts, Shell, Perl!? Kay-Uwe Kasemir
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
