1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bug in gcc
To: [email protected]
Cc: [email protected]
Date: Mon, 10 Feb 1997 16:33:37 -0600 (CST)
    Folks,
The problem I was having with medm crashing on a DEC Alpha machine has been
solved.
The fundamental problem was the bug in Channel Access in R3.12.2 which Jeff
Hill just described.  The low-order 32 bits of doubles were not being
byte-swapped correctly.
The contributory problem was the bug in gcc which I described last week.  gcc
2.2.3.1 is generating -0.0 values rather than 0.0 in certain circumstances.
-0.0 is a legal floating point value (though not what was intended).  However,
when -0.0 is passed through Channel Access with the byte-swap bug, then it
results in an invalid (denormalized) floating point number, which crashes medm.
When trying to track down the problem I built all of R3.12.2 with a more
recent version of gcc, 2.5.8.  This version does not have the -0.0 bug. EPICS
base compiled fine, but crashed with an access fault in a device
initialization routine before iocInit.  Is anyone running EPICS compiled on a
more recent version of gcc? 2.2.3.1 is more than 4 years old, and it is likely
that other bugs besides this one have been fixed since then.
____________________________________________________________
Mark Rivers                             (773) 702-2279 (office)
CARS                                    (773) 702-9951 (secretary)
Univ. of Chicago                        (773) 702-5454 (FAX)
5640 S. Ellis Ave.                      (708) 922-0499 (home)
Chicago, IL 60637                       [email protected] (e-mail)
or:
Argonne National Laboratory             (630) 252-0422 (office)
Building 434A                           (630) 252-0405 (lab)
9700 South Cass Avenue                  (630) 252-1713 (beamline)
Argonne, IL 60439                       (630) 252-0443 (FAX)
Prev: bug report (little endian and IEEE FP) Jeff Hill
Next: RE: mbbiDirect and mbboDirect changes in r3.13x Eric Bjorklund, NPSM
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Bug in gcc Mark Rivers
Next: How to Add/Delete your Name from a list Bill McDowell
