1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Archiving question(s)
To: [email protected]
Cc: [email protected], [email protected]
Date: Wed, 26 Feb 97 07:46:12 MST
> From [email protected] Tue Feb 25 18:42:33 1997
> Return-Path: <[email protected]>
> Date: Tue, 25 Feb 1997 15:39:58 -1000 (HST)
> Subject: Archiving question(s)
> Mime-Version: 1.0
> Content-Type> : > text/plain> ; > charset=us-ascii>
> Content-Transfer-Encoding: 7bit
> Content-Md5: l9Yb5y/+c32OmqgL7cpURg==
> Content-Length: 716
> X-Lines: 23
> After first consulting the "Phrase Finder" and then Nick I am
> still stuck trying to get AR to archive any data.
> Following questions:
> - In our current (test) setup the channel values don't change. I read
> that setting ADEL to a negative value should overcome the non-archiving
> of constant channels, but it still doesn't. AR doesn't complain about
> the .req file, connections are established, it just doesn't write a file.
> Any ideas why?
> - Which way is archiving going?
> The latest version of AR we have came with 3.13.0.alpha3.
> There is archiving effort at DESY.
> There is the frequency archiver.
> As we don't have any EPICS archiving experience here, we could
> go either way.
> Thanks in advance,
> Maren Purves
> UKIRT
Hi Maren,
Do you have at least one of your channels that is always changing?
If not, make yourself a counter and add it to the list.  Then
make all the rest of your channels filled. I think you must add
an F to the beginning of the request.
The current AR archiver is set up so that it will only archive when at
least one channel has changed.
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs AOT-8  FAX (505) 665-5107         |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Prev: Re: Archiving question(s) Chip Watson
Next: Re: Archiving question(s) Matthias Clausen DESY -MKS-2/KRYK-
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
