1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks file i/o problem
To: Len Lawrence <[email protected]>
Cc: tech-talk EPICS <[email protected]>, Sean Prior <[email protected]>
Date: Wed, 5 Mar 1997 16:32:44 +0000 (GMT)
Are you using NFS or not?
I had a possibly related problem which was confirmed by
Wind River as a known problem (it is in 5.2 & 5.3 and
they stated that they do not intend to fix in 5.2 due to
it being 'non-critical'). Basically it means that unless
you are using NFS you cannot tell whether a file exists
when you try to open it. WRS bug report was :
SPR #: 5227
PRODUCT: 5.3 Beta-1
ARCH: All
BOARD: All
HOST: N/A
DESCRIPTION:
If you try to open a non-existing file (without NFS) the fopen()
succeeds and the "contents" of the file is the error message returned
by Unix. The routine fopen() should return NULL if the file doesn't
exist.
WORKAROUND:
None.
Philip
Philip Taylor, Royal Greenwich Observatory,
Madingley Road, CAMBRIDGE. CB3 0EZ. UK
Email : [email protected]      Phone : (UK+) (0)1223-374710
VxWorks file i/o problem Len Lawrence
Prev: VxWorks file i/o problem Len Lawrence
Next: Re: VxWorks file i/o problem Jeff Hill
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
