1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bizarre MEDM problem
To: [email protected]
Date: Wed, 16 Apr 1997 17:16:12 -0400 (EDT)
	Hi.  I've created an MEDM gui to display the high voltage readout
from each channel of a LeCroy 1458 high voltage crate.  All of the
displays of the channels should be in decimal format, i.e. 1460 or -1460,
etc.  When I start MEDM it seems that channels are displayed in
exponential format at random.  For instance, if I look at the card in
slot 1, 50 of the channels will be displaying correctly, but the other 50
are in exponential format.  If I un-execute MEDM and restart it then
usually some different channels are being displayed in exponential
format.a The ones in exponential format are impossible to read, so I
would like to be able to solve this.  Has anyone seen this before?
Thanks, Kathy McCormick
"I'd mock you, but the challenge is gone" Dogbert
Kathy McCormick
[email protected]
Work Numbers: ODU: 1-757-683-3440 TJNAF Cubbie: 269-7340 Pager: 680-0076
Not Work: 851-7487
Re: Bizarre MEDM problem Bonnie Madre
Prev: sun workshop compiler bug Norm Hill
Next: Re: Usage of OffPage Input/Output ? Andy Foster
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Bizarre MEDM problem Bonnie Madre
