1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: steppermotor record problems
To: Gemini <[email protected]>
Cc: tech-talk EPICS <[email protected]>
Date: Fri, 23 May 1997 16:56:34 +0100 (BST)
At the Royal Observatory Edinburgh we have a problem in driving
several motors at once via the EPICS "steppermotor" record and the OMS
8-axis stepper motor drive card. We are being advised by our colleagues
at the Royal Greenwich Observatory to dump the record in favour of the
"motor" record which is in use at APS. Have others experienced similar
problems?
The motors we are driving control (currently) four mechanisms within the
Michelle imager/spectrometer being built here for use on UKIRT and
Gemini. The datuming of the mechanisms involves "stop on microswitch"
operations (steppermotor STHM to 2 or 3) and also "binary search" motions
in which a mechanism edges towards its datum microswitch whose state is
sensed after every move. Control of the sequencing involved in these
searches is through SNL code triggered by EPICS records, specifically
Gemini CAD records.
We find that mechanisms datum reliably individually or in pairs, but
that attempts to datum four mechanisms at the same time invariably fail
unless successive move demands are issued from the SNL at a very slow
rate (< 2Hz). Three motors at once usually works, but sometimes doesn't.
When a mechanism fails (not always the same mechanism or the same state)
it appears that either the expected move does not start, or else the current
motion does not complete.
After exhaustively walking through the SNL code, and peppering it with
diagnostics, we are reasonably confident that this is not a case of the
variables within one state set trampling over those of another.
Len
Len Lawrence                       Tel.   : +44 (0)131 668 8255 (direct)
Royal Observatory                           +44 (0)131 668 8100 (switchboard)
Blackford Hill                     [email protected]
Edinburgh EH9 3HJ                  aka [email protected]
UK                                 WWW    : http://www.roe.ac.uk/lclwww/
Prev: EPICS_CA_ADDR_LIST 80 character limit Jeff Hill
Next: R3.13.0.beta release for HP-UX Johnny Tang
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: steppermotor record problems Hubert Yamada
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
