1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CA and EPICS_CA_ADDR_LIST -> EPICS_CA_ADDR_FILE
To: <[email protected]>, <[email protected]>, "Matthias Clausen DESY -MKS-2/KRYK-" <[email protected]>
Cc: "Jeff Hill" <[email protected]>, <[email protected]>
Date: Fri, 30 May 1997 18:26:52 -0600
> From: Matthias Clausen DESY -MKS-2/KRYK- <[email protected]>
> To: [email protected]; [email protected]
> Cc: [email protected]
> Date: Friday, May 30, 1997 1:08 PM
> The question of getting access to remote (off subnet) IOC's is a common
one.
> The limit in the env. vars is maybe also good because we might end with
addr-lists of too
> many nodes. None the less I want to propose to add a new env. var like:
EPICS_CA_ADDR_FILE
> where you can enter all your IOC's you want to talk to. This might be a
performance hit to
> the client and therefore it should not be implemented on the IOC clinet.
> Another solution might be the ca_name_server which we heared about during
the EPICS
> workshop and which might have another implementation based on the
portable ca_server.
> If this solution would be available already for 3.13 (Jeff??) many of us
would not need to
> argue any more about the limitations in EPICS_CA_ADDR_LIST.
I intend to slip this small change (allowing the ca server to provide name
resolution services) into EPICS 3.13.
Jeff
Prev: Re: CA and EPICS_CA_ADDR_LIST -> EPICS_CA_ADDR_FILE Matthias Clausen DESY -MKS-2/KRYK-
Next: Re: IOC error message Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
