1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Serial Ports on MVME167 Card
To: [email protected], [email protected]
Date: Wed, 4 Jun 1997 13:38:19 -1000
Guy Jennings wrote:
> Is there any fundamental reason why we don't use the serial ports on the
> MVME167 Card in
> Epics?
> We have successfully used them to control SR570 current amplifiers.   It
> requires a small
> patch to vxWorks to add an ioctl call to change the number of stop
> bits.   If you have fewer
> than three serial devices interfaced per IOC (as we have) this allows
> you to dispense with
> the MVME162 card and IP modules etc.
We use a terminal server after we found that our serial devices have
one property that can't be set in the setup in a VT320 and as the terminal
server ports are already set up use the same setup for EPICS.
(Using a slightly modified version of drvAscii from Allan Honey of
Keck Observatory, drvSerial (from Jeff Hill) and tnetDev (from Bret
Goodrich of Gemini). We don't know how many serial devices we're going
to end up with.
Maren Purves
Prev: copying of monitored data William Lupton
Next: Re: Serial Ports on MVME167 Card Bonnie Madre
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Serial Ports on MVME167 Card Bonnie Madre
Next: Re: Serial Ports on MVME167 Card Tim Mooney
