1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: copying of monitored data
To: [email protected]
Date: Thu, 05 Jun 1997 08:58:27 -0500
William Lupton wrote:
> Dear all,
>   I have a stringin that can be processed several times rapidly in
> succession with a different .VAL field each time. I get a monitor for
> each time it is processed. However, the monitored values are mostly the
> same.
>   Is there anything I can do to prevent this behavior? I am still
> running EPICS R3.13.0.
array and string scalar values are not queued.
What happened to you is the following:
multiple db_post_event calls were made before the CA server
got a chance to run. Since string values are
not queued it just retrieved the latest value.
Marty Kraimer
copying of monitored data William Lupton
Prev: Re: DB initialization Marty Kraimer
Next: Re: Epics field names > 4 chars OK? Marty Kraimer
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: copying of monitored data William Lupton
Next: Re: copying of monitored data William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
