1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: copying of monitored data
To: [email protected]
Date: Tue, 10 Jun 1997 15:10:53 -0500
Jeff wrote,
>It does appear to work that way here also. This _is_ surprising
>behavior when you are attached to the .VAl field of a bo.
>After closer inspection I discovered that the get_enum_str() entry >point
>in the bo record is not using the field pointed to by paddr. Instead it
>always uses the val field. I would classify this behavior as a bug for >the
>following reasons:
I agree that nthis is wrong.
Marty Kraimer
Prev: Re: copying of monitored data Marty Kraimer
Next: Re: IOC hangs (scanOnce crashes) Chip Watson
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: copying of monitored data Jeff Hill
