1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: copying of monitored data
To: [email protected]
Date: Wed, 11 Jun 1997 09:15:24 -0500
Jeff is correct.
This will be fixed in next 3.13 release.
The affected record types are bi, bo, mbbi, mbbo.
Marty
Jeff Hill wrote:
> > HOWEVER,
> > The biRecord.c support code is not incorrect because there get_enum_str,
> > put_enum_str, get_enum_strs will ONLY get called if the field type
> > in question is DBF_ENUM. The only such field in the biRecord is VAL.
> > Many record support modules in base make this assumption.
> Yes, but PV values in the CA server monitor queue will be ignored in favor
> of the current value in the record if we leave the code as it is today.
> Therefore, clients that monitor the .VAl field of a bo record as a
> string will see the sequence of events "on off on" converted
> to "on on on" if the events are spaced closely together in time.
> Explanation:
> This is because, when dbGetField() is called, the dbAddr structure
> is pointing at the value on the CA monitor queue and not at the
> .VAL field. The bo record's get_enum_str() routine ignores the
> dbAddr structure passed in and always converts  the VAL field
> to a string (returning the current and not the historic value of
> the .VAL field).
> Jeff
Re: copying of monitored data Jeff Hill
Prev: Re: ACS Microstepper Drives Kurt A. Goetze
Next: Re: IOC hangs (scanOnce crashes) Marty Kraimer
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: copying of monitored data Jeff Hill
Next: 167 serial ports Garrett D. Rinehart
