1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ACS Microstepper Drives
To: [email protected]
Date: Wed, 11 Jun 1997 11:21:11 +0000
Kurt A. Goetze wrote:
> Guy Jennings said:
> > Just ran into a potential gotcha with the ACS SPD-3M Microstepper
> motor
> > drive module.=A0=A0 It is NOT a drop-in replacement for the SPD-6U
> > drive!!!=A0=A0 The SPD-3M is a bipolar drive and needs different
> connections
> > when used with a 6-wire motor.
> > Users beware!!!
> I guess I would like to know more about how your motor is wired up.=A0
> My
> experience is that the SPD3M worked well as a drop-in replacement for
> the
> unipolar StepPak drive (using a 6 or 8 lead motor).
> Kurt Goetze
> APS/XFD/Beamline Controls
=A0 We are using the connections in the APS 'standard' (I think!).
For the SPD-6U:
ELCO=A0=A0=A0 Signal=A0=A0=A0 SLO-SYN 6-lead
A=A0=A0=A0=A0=A0=A0 Ph 1 Out=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0 Ph 2 Out=A0=A0=A0 Red/White
C=A0=A0=A0=A0=A0=A0 Ph 3 Out=A0=A0=A0 Green
D=A0=A0=A0=A0=A0=A0 Ph 4 Out=A0=A0=A0 Green/White
E=A0=A0=A0=A0=A0=A0 Ph 1 Ret=A0=A0=A0 Black
F=A0=A0=A0=A0=A0=A0 Ph 2 Ret=A0=A0=A0 Black
H=A0=A0=A0=A0=A0=A0 Ph 3 Ret=A0=A0=A0 White
J=A0=A0=A0=A0=A0=A0 Ph 4 Ret=A0=A0=A0 White
This corresponds with Fig. 4.2 on page 17 of the ACS manual (Jan 1997).
This does not match up with any of the connection diagrams on page 24 or
25 of the
ACS manual.
I was able to succesfully move the motor with the following connections:
A=A0=A0=A0=A0=A0=A0=A0 Ph 1+=A0=A0=A0 Red
B=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
C=A0=A0=A0=A0=A0=A0=A0 Ph 3+=A0=A0=A0 Green/White
D=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
E=A0=A0=A0=A0=A0=A0=A0 Ph 1-=A0=A0=A0 Red/White
F=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
H=A0=A0=A0=A0=A0=A0=A0 Ph 3-=A0=A0=A0 Green
J=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 NC
This corresponds with Fig. 5.2 on page 25 of the ACS manual.
Interestingly enough, we had previously tried the microstepper drives
with an
8-lead motor and found no problems.
Re: ACS Microstepper Drives Kurt A. Goetze
Prev: Re: IOC hangs (scanOnce crashes) Ralph Lange
Next: [Fwd: ACS Microstepper Drives] jennings
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ACS Microstepper Drives Kurt A. Goetze
Next: Re: ACS Microstepper Drives Pete Jemian
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
