1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Allen-Bradley serial support
To: [email protected], [email protected]
Date: Wed, 12 Nov 1997 10:24:18 -0800 (PST)
We are using the Allen Bradley DF1 serial device support for the
Gemini Enclosure Control System.   On booting the IOC we are getting
the following error message at least one in three times.......
iocInit "./data/resource.def"
###  @(#)EPICS IOC CORE
###  @(#)Version R3.12.2Gem4.1
task: 0Xfaabb8 tShell
Error status (module 1001, number 3) not in symbol table
Unable to install AB serial word IO
0xfaabb8 (tShell): iocInit: All initialization complete
value = 0 = 0x0
Only a re-boot (and the usual graphic expletives) allows us to proceed.
This has been a regular occurrence since we received the initial copy of the
device support code.   We have loaded databases with only AbDf1 records
to try and eliminate possible intractions but get the same results.
Has anyone else experienced this problem and, even better, found
a solution???
				William Rambold
				DAO
Allen-Bradley serial support Peregrine McGehee
Prev: CA Client Messages from the dbCA task handling record links between IOCs saa
Next: Allen-Bradley serial support Peregrine McGehee
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
