1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS r3.13 field VERS
To: [email protected]
Date: Tue, 03 Feb 1998 11:24:55 -0600
There seemed to be a consensus that it is a good idea to have a field
VERS in each record. There was no consensus about how this field is
given a value. The only ways I see that are easy to implement are:
1) Give an initial value in the .dbd file
2) make the developer give a value via the init routine of the record
support module.
I originally suggested 1) but have changed my mind. Either it is done
automatically or the developer has to remember to change the .dbd file
when any change is made in the record support module. In spite of some
suggestions I dont see an easy way to do it automatically. Note that
version should change ONLY when the .dbd file or record support module
are changed. The developer is likely to forget to change the .dbd file
when only the record support module is changed. Thus I vote for 2).
This means that we could put something like
field(VERS,DBF_STRING) {
    prompt("Version Number")
    special(SPC_NOMOD)
    size(40)
This could go into dbCommon
Then a record support init_record routine could contain:
    strcpy(precord.vers,"xxx.yy");
Questions:
1) Should the field type be DBF_STRING?
2) Should there be rules about how version numbers are assigned?
3) What about all the existing record support modules?
Marty Kraimer
Prev: Re: proposed RTYP field Marty Kraimer
Next: Re: proposed RTYP field Ralph Lange
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: alh group reset mask question William Lupton
Next: Re: EPICS r3.13 field VERS and RTYP Marty Kraimer
