1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: proposed RTYP field
To: [email protected]
Date: Tue, 3 Feb 98 11:44:57 CST
> This finally got to the top of my TODO list.
> There was a lot of discussion about how to implement this feature.
> The main ideas were:
> 1) Provide a field RTYP in every record.
> 2) Provide a new Channel Access Request type.
> I agree with the second alternative.
> Jeff Hill suggested that we have a new request type DBR_CLASS_NAME.
> For example:
> char        classname[80];
> SEVCHK(ca_get(DBR_CLASS_NAME,mychid,&classname),"ca_get");
> SEVCHK(ca_pend_io(waitTime),"ca_pend_io");
> printf("pv: %s classname %s\n",ca_name(mychid),classname);
> I modifyied db_access.h, db_access.c, and the ca/convert.c to implement
> the change. Jeff will still have to look to see if any other channel
> access changes are necessary if new clients talk to old servers.
> Marty Kraimer
Thanks for the action on the RTYP/classname topic.
I'm confused how I use this from, say, the UNIX command line
or from a SNL sequence program.
>From the UNIX command line, I can use the
<EPICS>/extensions/bin/<arch>/caget command.
Can I figure out the RTYP/classname with this tool?
How do I figure out the RTYP from a sequence program?
These are probably silly questions but these two cases represent
the two situations that I would be using this information.
  UNIX: smart GUI tools (e.g., Tcl/Tk) that can be told how to
        represent different record types and provide a default
        configuration based on just the PV name
  SNL:  auto-configure program for finding all the "motor" records
        at boot time and coordinating "allstop" functions with each motor.
   Pete Jemian
   UNICAT
Re: proposed RTYP field Marty Kraimer
Prev: Re: proposed RTYP field Ralph Lange
Next: Re: EPICS r3.13 field VERS Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: EPICS r3.13 field VERS Marty Kraimer
Next: Re: proposed RTYP field Marty Kraimer
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
