1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS r3.13 field VERS
To: [email protected]
Date: Tue, 03 Feb 1998 14:10:10 -0600
Sally Schaffner wrote:
> Subject:
>         It should probably be a string because then things like
>         "1-0" or "1-0a" or "R313.1-0" can be used.
> > 2) Should there be rules about how version numbers are assigned?
>         It will be very difficult to come up with rules that will
>         be flexible enough to accomodate all types of EPICS
>         installations especially since they are so varied. It is
>         probably best to let each institution come up with versioning
>         rules that make sense for them.
> > 3) What about all the existing record support modules?
>         The field should default to something like "1-0" or
>         some other obvious baseline type nomenclature. Then
>         it can build from there.
Maybe it is better to just leave the string null to indicate never set.
Marty
Prev: Re: EPICS r3.13 field VERS and RTYP Marty Kraimer
Next: RE: EPICS r3.13 field VERS Jeff Hill
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS r3.13 field VERS and RTYP Chip WATSON
