1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Greenspring rs422 support
To: "Peregrine M. McGehee" <[email protected]>
Cc: "Joseph P. Sullivan" <[email protected]>, [email protected], [email protected]
Date: Wed, 11 Mar 1998 11:00:15 -0600
Peregrine M. McGehee wrote:
> > We also decided it was safer not to output the first character from
> > the Write function.
> Why is that? How do you start the transmit cycle? In my case this occurs in
> the transmitter startup routine which is equivalent to the Write fucntion
> in the HiDEOS driver.
When you enable the transmit interrupt an interrupt will occur as soon
as the 1 character transmit buffer is empty, i.e. almost always
immediately.
Here are some reasons for NOT outputing a character from the Write
(startup) routine.
A) NEVER do the same thing in 2 different places unless you have a VERY
good reason.
B) to put a character three things must happen:
1) the character must be copied from the memory buffer to the transmit
buffer.
2) The memory buffer pointer must be incremented.
3) The number of characters to transmit must be decremented.
If these three operations are done in more than one place you MUST get
exclusive access while the three operations are occuring.
The following should be safe:
Write does the following:
1)If the transmit mask is already set ignore the request, i.e. an
attempt is being made to sent 2 messages on the same port at the same
time.
2) Set the buffer pointer and number of characters used by interrupt
service routine.
3) Enable the transmit interrupt mask bit (must lock because it is
shared with other ports).
The interrupt routine
1) uses transmit mask and transmit ready to decide when to move a
character to the transmit buffer.
2) turn off transmit mask when last character sent or error occurs.
I agree with  Peregrine that the SR should be used to check for errors.
Marty Kraimer
Re: Greenspring rs422 support Andrew Johnson
Re: Greenspring rs422 support Peregrine M. McGehee
Prev: Re: synchronizing client requests & completions Peregrine M. McGehee
Next: Re: Greenspring rs422 support Andrew Johnson
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Greenspring rs422 support Peregrine M. McGehee
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
