1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: synchronizing client requests & completions
To: [email protected], [email protected]
Cc: [email protected], [email protected]
Date: Thu, 12 Mar 1998 10:27:54 -0600
re...
> The essence of the mechanism needed is a state transition from "ready" to
> "busy" synchronously as the request is posted so that subsequent state
> queries cannot temporarily see a "ready" and be misled. Multi-record
> solutions tend to produce race windows and get out of synchronization.
The transition to "busy" need not be prompt if your completion detector looks for a
*transition* from "busy" to "ready" instead of looking only at the level of the
signal.  The wait record is great for this because it can be instructed to execute
its output link only on a transition.  (The full list of possibilities is "Every
Time", "On Change", "When Zero", "When Non-zero", "Transition To Zero", and
"Transition To Non-zero".)
We've been using the wait record in a primitive completion-detector database that
logically OR's all relevant busy signals, and signals completion when the result
makes a transition to zero.  This simple-minded completion detector fails when one
busy signal makes 0-1-0 transitions before another signal has made its 0-1
transition, but that's just because it uses a logical OR instead of counting 1-0
transitions as you plan to do.  (We don't count transitions because we want to
support scans of compound motions programmed by users at run time, so we can't
know in advance how many actual devices are being scanned.  So far, the benefits
have been well worth the problems, but it would be nice to minimize the
problems, and we're looking at ways to do this.)
Tim Mooney
Prev: Re: Proposal for boosted Symb device support Ned Arnold
Next: RE: Proposal for boosted Symb device support Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: synchronizing client requests & completions Peregrine M. McGehee
Next: RE: synchronizing client requests & completions Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
