1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: synchronizing client requests & completions
To: [email protected]
Cc: [email protected]
Date: Thu, 12 Mar 1998 08:47:37 -1000
Dear all,
Tim Mooney wrote:
> The transition to "busy" need not be prompt if your completion detector
> looks for a *transition* from "busy" to "ready" instead of looking only
> at the level of the signal.  The wait record is great for this because
> it can be instructed to execute its output link only on a transition.
> (The full list of possibilities is "Every Time", "On Change", "When
> Zero", "When Non-zero", "Transition To Zero", and "Transition To
> Non-zero".)
I would just like to point out that EPICS R3.13 supports a new "CPP"
input link attribute which says "make a link a CA link and process a
passive record whenever the referenced channel delivers a CA monitor".
This is very powerful (you can use it on _any_ input link) and has
replaced our use of the wait record.
William
Prev: RE: synchronizing client requests & completions Jeff Hill
Next: Re: Proposal for boosted Symb device support William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: synchronizing client requests & completions William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
