1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: BUG in Record Reference Manual R3.13
To: [email protected] (EPICS Tech-Talk)
Date: Thu, 19 Mar 1998 20:12:51 +0100 (MET)
The forth paragraph in Chapter 30 (Sequence Record) Section 5 (Selection
Algorithm Parameters) of the Record Reference Manual R3.13 is wrong:
Instead of
When Mask is chosen, each time the record is processed, the record uses the
integer value from the SELN field as the number of links to process,
starting with the first link. For instance, if Mask is 3, then the record
will retrieve the values from DO1-DO3 and write them to the locations in
LNK1-LNK3.
it should read
integer value from the SELN field as a mask to determine the links to
process. For instance, if SELN is 1, then the value from DO1 will be
written to the location in LNK1. If SELN is 3, the record will retrieve the
values from DO1 and DO2 and write them to the locations in LNK1 resp.
LNK2. If SELN is 63, DO1...DO6 will be written to LNK1...LNK6.
Ralph
Re: BUG in Record Reference Manual R3.13 Ralph Lange
Prev: April Collaboration Meeting Bob Dalesio
Next: 3.13 Install question Andrew Johnson
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: BUG in Record Reference Manual R3.13 Ralph Lange
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
