1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Stops in the motor record
To: [email protected]
Date: Thu, 26 Mar 1998 11:45:31 -0700
To users of the motor record:
This code segment from recMotor.c is causing me some problems.  Stops are issued
when they should not be.  I think this is happening because the axis is queried
before it has started moving and the last move was in the opposite direction from
the current move.
Has this been a problem for others?  What would you recommend doing to fix it?
Debug statements with my comments are below as well.
Janet Tvedt
Janet Tvedt, Engineering Technical Services     Internet: [email protected]
National Optical Astronomy Observatories        Phone:    (520) 318-8388
950 N. Cherry Ave., Tucson, AZ  85719           FAX:      (520) 318-8360
Code Segment
			 * Are we going in the wrong direction?  (Don't be
			 * fooled by a backlash correction into saying "yes".
			 * 'Jog*' and 'Hom*' motions don't get midcourse
			 * corrections since we don't know their
			 * destinations.)
			Debug(10, "process: rvel = %d\n", pmr->rvel);
			if ((fabs(pmr->diff) > 2 * (fabs(pmr->bdst) + pmr->rdbd)) &&
			    ((pmr->rval > pmr->rrbv) != (pmr->tdir == 1)) &&
			    (pmr->rvel != 0) && (MARKED(M_RRBV)) &&
			    ((pmr->mip == MIP_MOVE) || (pmr->mip == MIP_RETRY))) {
				 * We're going in the wrong direction.
				 * Readback problem?
				Debug(2, "process: wrong direction, diff = %f\n", pmr->diff);
/*				printf("%s:tdir = %d\n", pmr->name, pmr->tdir);*/
				INIT_MSG();
				WRITE_MSG(MOTOR_STOP_AXIS, NULL);
				SEND_MSG();
				pmr->mip |= MIP_STOP;
				MARK(M_MIP);
Debug Statements
sent message (AX QA RP RE EA
recv_mess: card 1 com PDNN,26130,4863,DDNNNN
info = (PDNN,26130,4863,DDNNNN)
sent message (AX RA
recv_mess: card 1 com PDNN                              <=========== last move in Pos direction
sent message (AX AF VB37 VL2048 AC1024 MR-767 GD AN IP  <=========== new move in Neg direction
recv_mess: card 1 com PNNN,26129,4864,DDNNNN            <=========== first QA still says Pos direction
info = (PNNN,26129,4864,DDNNNN)
recv_mess: card 1 com MNNN,26127,4864,DDNNNN            <=========== next QA is correct
info = (MNNN,26127,4864,DDNNNN)
sent message (AX AF ST AN IP                   <==================== stop already issued
recv_mess: card 1 com MDNN,26117,4864,DDNNNN
info = (MDNN,26117,4864,DDNNNN)
sent message (AX RA
Re: Stops in the motor record Graham Waters
Prev: May 98 Collaboration Meeting Bob Dalesio
Next: Re: Stops in the motor record Graham Waters
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
