1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Stops in the motor record
To: [email protected] (Tim Mooney)
Cc: [email protected]
Date: Mon, 30 Mar 1998 18:34:59 -0600 (CST)
> Hubert, re...
> > -- On Mar 27, 1998, [email protected] (Tim Mooney) wrote
> > > I should mention that glitches on the limit-switch lines can produce
> > > very similar behavior, and are by **far** the more common cause of it.
> > > So don't everybody with an intermittently jerky motor immediately assume
> > > their hardware is flakey.  You might just need some decoupling capacitors.
> > I'm not sure that this is true.  I've seen this behavior very regularly
> > (with the .27 release of the motor record, VME8-8 board).  I don't have
> > any limit switches in my system and limit-switch support has not been
> > enabled.
> Wait a minute.  You can't enable or disable limit switch support, and the
> hardware doesn't care whether or not you actually have switches.
We have seen this behavior with the OMS boards when we were not using
epics.  It can be tricky to diagnose since noise on the limit lines
gives a limit switch trip, but only an intermittant one, so that the
software doesnt actually have time to trap the error as a limit problem.
All you see is that the motor intermitantly stops.  Capacitors on the limit
lines (as close to the oms boards as possible as with Kurt Goetz's paddle
board) seem to cure this problem. OMS also claims that the MMI
PAL chips on the limit lines are particularly susceptible to the problem and
that switching to TI PAL chips limits the effect.
Larry
Laurence Lurio
IMM-CAT
Sector Number 8
APS/ANL
Building 400                               VOICE:     630-252-0281
9700 South Cass Avenue                       FAX:     630-252-0282
Argonne, IL 60439-1749                     EMAIL:  [email protected]
Re: Stops in the motor record Tim Mooney
Prev: Re: Stops in the motor record Tim Mooney
Next: Re: Stops in the motor record Hubert Yamada
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
