1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CA Server
To: [email protected]
Date: Tue, 31 Mar 1998 13:36:05 -0700
> From [email protected] Tue Mar 31 12:28 MST 1998
> To: "tech talk" <[email protected]>
> Date: Tue, 31 Mar 1998 13:27:39 -0600
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7bit
> X-Priority: 3
> X-Msmail-Priority: Normal
> X-Mailer: Microsoft Outlook Express 4.72.2106.4
> X-Mimeole: Produced By Microsoft MimeOLE V4.72.2106.4
> X-Lines: 25
> You know . . . if people documented  and posted the info on all the various
> small widgets and snippets of code and routines that get created, the rest
> of the known universe would not have to dig through source code to try to
> find out how to use them . . . and a lot of the messages posted to these
> lists might just vanish.
> Wonder just how much of everyone time has been spend trying to figure out
> what all this stuff does and how it is supposed to work for themselves since
> there seems to be no other way to obtain the required information.
> Me
Hi Me,
Sorting through documentation is sometimes a lot harder than sorting through
the code.  At least with code you know what part of the system
you should look at and you are sure it is up to date.
There is a reference to
several EPICS_CAS environmental variables in the channel access
reference manual available at the LANL Epics site
Section  1.7  on Configurating a CA server.  There is also a comment that this
chapter of the document is "under construction".  This probably explains why
EPICS_CAS_INTF_ADDR_LIST has not made it into the documentation yet.
Perhaps it will happen this summer if our technical writer comes back from
school or if Jeff can get enough time off the phone answering EPICS questions
so that he can update the documentation himself.
Meanwhile if someone else has a problem with a CA Server they can
do a search for the pattern "CA,Server" in the Epics Listserver Archives on
the top level of the EPICS Home page
and can find the solution that John Sinclair so kindly posted to this
mail list.
Jeff will be back from Spring Break on Monday and may have some comments on
this topic himself.
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs LANSCE-8  FAX (505) 665-5107      |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
> -----Original Message-----
> From: john sinclair <[email protected]>
> To: tech talk <[email protected]>
> Date: Tuesday, March 31, 1998 1:16 PM
> >I have found a solution: . . . . It is nice having the source code!
Prev: Re: CA Server Arun S, Bommannavar
Next: Re: CA Server Maren Purves
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: CA Server Steven M Beard
Next: RE: CA Server Hammonds, John
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
