1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on Linux
To: "'Super-User'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Thu, 2 Apr 1998 00:34:48 -0600
Dear Yujong,
I am only using Linux as a client workstation.  This does not require
VxWorks.  I still use a Sun Solaris machine to build EPICS applications
for the IOC.  On the Sun (a sparcStation) I use VxWorks 5.2 dev kit.
This is probably also available on x86 Solaris but you may have some
work to do to compile EPICS.
Actually someone else installed that but I do use it.  On the client
side (ie Linux) I have built quite a few of the apps (MEDM, StripTool,
...) and use these to interface with the workstation.
Redhat Motif comes from RedHat.  This is also where I get my Linux from.
See www.redhat.com.
I have used a variety of x86 Machines w/ Linux.  I have one running as
an X-terminal that is only a 386-SX16.  I recommend getting as much PC
as your budget allows so that you can better utilize it.  I really
recommend a Pentium class as a minumal starting point unless you simply
cannot lay your hands on anything else.  As with any other computer
question memory never hurts either.
I hope that this helps,
John
> -----Original Message-----
> From:	Super-User [SMTP:[email protected]]
> Sent:	Wednesday, April 01, 1998 7:54 PM
> Subject:
> Dear Hammonds, John
> I am a graduate student of POSTECH in Korea
> POSTECH and POSCO built PAL [=Pohang Accelerator Laboratory]
> I read your mail in teck-talk mail archives for EPICS on Linux.
> I have some question about EPICS on Linux.
> My questions:
> 1) I think that in order to install epics-3.13b11 on unix machine,
> 	Tornado or Vx-Works for Unix must be needed.
> 	Is there Tornado-1.0.1 or Vx-Works for Linux or X86 Solaris2.x ?
> 	What type Tornado or VxWorks did you use to install
> epics-3.13b11
> 	on Linux  ?
> 2) How can I obtain Redhat Motif 2.0.1 ?
> 3) How much memory do you need for run epics on your Linux
> 	machine ?
> 4) How fast CPU do you need for run epics on your Linux machine ?
> I hope to receive your answer soon.
> Thanks for your Helps.
> from Yujong Kim
> [email protected]
> [email protected]
Prev: CA Server humor Paul Sichta
Next: Re: CA Server humor Tim Mooney
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS on LINUX Hammonds, John
Next: EPICS training Bob Dalesio
