1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: [Q or Help!] change of scanning period causes IOC crash.
To: "'Noboru Yamamoto'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 2 Jun 1998 11:38:47 -0600
Noburo,
As I recall, APS experienced some problems with the National Instruments
MXI hardware timing out during VXI bus transfers when they first set up their
MXI systems. Ned Arnold ([email protected]) might be able to provide some hints on
setting up MXI bus systems.
Jeff
On Tuesday, June 02, 1998 2:08 AM, Noboru Yamamoto [SMTP:[email protected]] wrote:
> Hi,
>  We are writing a device support routines for a VXI oscillo scope. We use
> MXI-bus connection to cnnect VME bus, where IOC is, and VXI bus , where
> an Osciloscope. When you satrted databse at one scanning period, the device
> support works OK. Some records send commands to setup measurement and a
> waveform record reads trace data from the osciloscope.
> However, we changes scanning period of the processing, IOC crashes.
> Actually it freeze.
>  Does anybody has a similar problem in developing device support? Which part
> of device support we should look at?
>  Your comments will be grately appricated.
Prev: Position Avaiable Hammonds, John
Next: Looking for statically linked MEDM 2.3.3 Brian McAllister
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: [Q or Help!] change of scanning period causes IOC crash. Noboru Yamamoto
Next: RE: [Q or Help!] change of scanning period causes IOC crash. Noboru Yamamoto
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
