1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Process-Valve icon color
To: [email protected]
Date: Fri, 5 Jun 1998 17:11:57 -0500
At APS the following color conventions are to be used when creating displays:
Any control button, slider, menu, related display, text entry etc that
makes something happen should be BLUE (second row blue in the MEDM
default color palette). This is useful because operators can quickly
observe "hot spots" on a display where they can make something happen
(change a value, call up another display, etc). The context or icon of
"the blue thing" should adequately convey WHAT will happen if they
click on it.
Text:
All text updates should be displayed on a background that allows all
alarm colors to be visible (if the alarm dynamic is set). We usually
use light grey or dark grey (almost black). Another "RULE OF THUMB"
that we tell the operators is "If the text is WHITE, don't believe the
reading. The computer cannot communicate to it".  Therefore, white
static text is discouraged.
Likewise, since RED, GREEN, and YELLOW reflect alarm conditions, these
colors should not be used for static text or text updates.
No colors are "disallowed" from being used for graphical images
(magnets, waveguides, etc) because it is usually very obvious that
these are pictures and NOT dynamic objects.
Colors:
DIN Standards 4844 and 5381 shall be followed whenever possible.
Red is the 'danger color' Halt, Stop, Prohibited etc.
Yellow is used as a warning color.
Green means safety, ok, on etc.
Blue is used for giving directions, advice, signs, etc.
Prev: RE: compilation of src/ca Jeff Hill
Next: Color rules john sinclair
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Process-Valve icon color Matthias Clausen DESY -MKS-2/KRYK-
Next: BITBUS availability... Udo BOTHNER
