> Everything has gone well for about 72 hours except for Medm. Medm runs
> fine and then, at some (apparently) random time, begins consuming virtual
> memory at a rate of about 1K bytes per second until all is consumed. There
> is no noticeable change in behavior or performance when Medm gets into this
> state (until the system starts swapping).
> I realize that the problem could be in the linux kernel, X libs, or C libs. I
> will try to build the test on another platform. Any comments/suggestions
> are appreciated.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 423-576-6362 423-574-1268 (fax)
John,
If you (or anyone else) find out what the problem with MEDM is, PLEASE let me
know. I'm still trying to track down the problem with mine (RH Linux 4.1, MEDM
2.3.3). I went so far as to set up identical machines and run them tandomly.
The original one does as always (medm dies every 6-7 hours), but a cron task I
set up restarts it. Medm on the "new" one never leaves the process list, but
it's quite dead nonetheless. Unfortunately, my cron task can't tell since it
finds medm in the process list, so I don't know how regularly this (would)
happen. In both cases, Linux and X continue unaffected.
-- Garrett Rinehart
Intense Pulsed Neutron Source
Argonne National Laboratory
Marty Kraimers UC Distinguished Performance Award Bill McDowell
CVS question jin yu
<1998>
2025
Portable channel access server on linux john sinclair
RE: Portable channel access server on linux Jeff Hill
<1998>
2025
