1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem solved ... Re: boot problems & related on hkbaja47
To: [email protected]
Date: Wed, 17 Jun 1998 14:39:42 -1000
Maren Purves wrote:
> Following Ned Arnold's advice I took the "I'll only want to do this
> once" approach and rebooted my workstation. Unfortunately that didn't
> help. Then I followed the rest of Rozelle's "Debugging EPICS ..."
> paper and found:
> My netmasks are ok.
> The cpu is not busy.
> "casr" says no clients are connected.
> I can't find any of my channels with cau.
> I thought I found it when I walked over to the (physical) console
> and found that it said that the database initialization failed
> (and below that said that the database initialization completed),
> but then remembered that it always does that (no idea why).
Well, I did end up doing it twice ... (the rebooting part).
What the problem ended up being:
Due to Nick and myself working on the same project on two crates we
had to put in access restrictions. Only, now Nick is on leave and
I'm using his crate (because somebody else is using mine). I took
the access resctrictions out of the crate, but not out of the
workstation ....
I guess logging out and back in would have accomplished getting rid
of them, but to make sure I rebooted again.
Thanks again,
Maren
Re: boot problems & related on hkbaja47 Ned Arnold
more details - Re: boot problems & related on hkbaja47 Maren Purves
Prev: RE: boot problems & related on hkbaja47 Jeff Hill
Next: RE: boot problems & related on hkbaja47 Jeff Hill
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: more details - Re: boot problems & related on hkbaja47 Maren Purves
