1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm: leading zeros
To: [email protected]
Cc: [email protected]
Date: Mon, 22 Jun 1998 10:11:52 -0500
> Is there a way to specify (in the record's PRECision field) to direct a medm
> text monitor to fill the displayed VALue with leading zeros?  I want the
> display to show '02',  not '2'.   In a printf statement the syntax would be
> %02d.
> -ps
No, not directly. If its REAL important you could write a simple device
support routine for a stringin record that puts it into whatever format
you want. The stringin record could fetch the value you want using the
.INP field.
	Ned
Re: medm: leading zeros Chip WATSON
Prev: medm: leading zeros Paul Sichta
Next: Re: medm: leading zeros Tim Mooney
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: medm: leading zeros Chip WATSON
