1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mv177
To: [email protected]
Cc: [email protected]
Date: Thu, 25 Jun 1998 16:05:29 -0500
> We are considering buying an "mv177" rather than "mv167"
> for one of the systems in our project.
> Are there any issues that I should be aware of running
> EPICS under vxWorks 5.2 on the "mv177"?
> Presumably we will need a new BSP. Does the same cross-compiler
> work for both boards - i.e. could you load a "167" image on
> the "177"?
We are using a few MVME177's as direct replacements. Yes you need a new BSP.
With EPICS R3.13, just add
CROSS_COMPILER_TARGET_ARCHS = mv167 mv177        in config/CONFIG
and
ARCH = mv177           in iocBoot/iocName/Makefile
and let the Makefiles do their magic.
At APS, MV177's don't seem to boot from fast solaris machines, we have to
specify a boot host that's running sunOs. This has not been a problem at
PPL, however, where they are running a later version of Solaris and vxWorks
5.3.
> Does anyone have speed comparisons between the two?
In my application, the mv177 accomplished the image processing algorithms in
a little less than half the time it took the 167 .... see below :
6/15/98   Using MV200support.c with edits up to 6/12 on an mv167
          calculating both X & Y ...
          No plots, No text  -    Total Field Process Time =  14725 usec
          No plots, text update - Total Field Process Time =  33153 usec
          Plots, No text -        Total Field Process Time =  27246 usec
          Plots, text -           Total Field Process Time =  45281 usec
          Using MV200support.c with edits up to 6/12 on an mv177
          calculating both X & Y ... (also fixed mv167-timer.c)
          No plots, No text  -    Total Field Process Time =   7166 usec
          No plots, text update - Total Field Process Time =  14701 usec
          Plots, No text -        Total Field Process Time =  12053 usec
          Plots, text -           Total Field Process Time =  19706 usec
	Ned
Prev: mv177 Andy Foster
Next: Re: mv177 Steve Lewis
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
