1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA monitor function pb
To: [email protected]
Date: Fri, 17 Jul 1998 10:46:44 +0100
Hello to all the CA gurus,
I have a list of Waveform records.
A C user function (USERFUNC declared with ca_add_array_event) is used to monitor
these channels. The USERARG parameter of ca_add_array_event is used to identify
the record which causes the call of the USERFUNC.
At the initialization, USERFUNC is normally called with the different USERARG
corresponding to all the waveform records.
But after this, USERFUNC is always called with the last USERARG as declared by
ca_add_array_event whatever the processed waveform record.
I run R3.12.2.
Many thanks for any help.
J.F. Gournay
                                |  Jean-Francois Gournay               |
                                |  DAPNIA/SIG                          |
                                |  CEA-Saclay                          |
                                |  F-91191 Gif-Sur-Yvette CEDEX        |
                                |  Phone : +33 (0)169087032            |
                                |  Fax   : +33 (0)169086301            |
                                |  E-Mail:  [email protected]            |
Prev: Sampling ADC Frank Lenkszus
Next: RE: CA monitor function pb Jeff Hill
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
